Jack,
Many thanks for your reply, I am very much an amateur at this. You prompted me to go and re-read the manuals more carefully.
The early Wallis 20-30 manual states “The rear main bearing has a lead through which the oil passes to the ball bearing on the end of the drive shaft and located inside the flywheel and then down along the side of the wall of the clutch chamber and when it has filled this chamber up to the bottom of the flywheel, it is picked up and returned to the crankcase.”
So, you are correct, some leakage past the plug is intentional and not just to lubricate the throwout bearing.
It bothers me that the fit between the drilled hole in the crankshaft and the plug isn’t defined in any way, especially as I can’t now find that plug on my workbench. Anyway, seems I should remove that setscrew and replace with a plug. Also probably don’t need any shield on the throwout bearing. Any thoughts? Interestingly the old throwout bearing I removed from the tractor was shielded on both sides, but who knows when that was installed.
Also while we are on the subject is the clutch facing material any different between a dry clutch and a wet clutch and if so where does one get it?
Alan Painter Brownsville, Oregon
