U Frame Enthusiasts,
You may have read my earlier questions concerning the steel plug in the end of the crankshaft on my 20-30. I had originally thought that the leakage of oil past the plug was merely to lubricate the throwout bearing so planned to install a new greased bearing and seal the hole in the crankshaft with a setscrew. Jack pointed out that the clutch also receives lubrication via this route and recommended I not seal it off. Since this Forum has become the repository for obscure information on our tractors I can now complete the story and archive it here.
Although I cannot find the original plug that fell out of my crankshaft I just discovered a note I had made long ago that the diameter of my plug was 0.235 inches and 1 1/2 inches long. The 2 inch deep hole in the end of my crankshaft just accepts a letter F drill 0.257inch diameter so there is clearance of about 0.011 around the plug. By my calculation that is the equivalent area of a hole 0.104 in diameter.
Fortunately it will be easy to replace the missing plug.
Many thanks for all your input.
Alan Painter
